Tips for Erratic Heart Rate Data If the heart rate data is erratic or does not appear, you can try these tips. Clean and dry your arm before putting on the device. Wear the band tightly above your wrist bone. NOTE: You can try wearing the device higher on your forearm. You can try wearing the device on your other arm. Warm up for 5 to 10 minutes and get a heart rate reading before starting your activity. NOTE: In cold environments, warm up indoors. Rinse the device after each workout. Clean the light seal on the back of the device, and check for signs of damage (Replacing the Light Seal). Parent Topic: Troubleshooting
Tips for Erratic Heart Rate Data If the heart rate data is erratic or does not appear, you can try these tips. Clean and dry your arm before putting on the device. Wear the band tightly above your wrist bone. NOTE: You can try wearing the device higher on your forearm. You can try wearing the device on your other arm. Warm up for 5 to 10 minutes and get a heart rate reading before starting your activity. NOTE: In cold environments, warm up indoors. Rinse the device after each workout. Clean the light seal on the back of the device, and check for signs of damage (Replacing the Light Seal). Parent Topic: TroubleshootingHomeTroubleshootingTips for Erratic Heart Rate Data
