Cleaning the USB Port Turn off the device and disconnect the device from power. Clean the USB port using a soft, clean, lint-free cloth or cotton swab. NOTE: If necessary, you can lightly dampen the cloth or cotton swab with isopropyl alcohol. Allow the device to dry completely before you connect it to power. Parent Topic: Device Care
Cleaning the USB Port Turn off the device and disconnect the device from power. Clean the USB port using a soft, clean, lint-free cloth or cotton swab. NOTE: If necessary, you can lightly dampen the cloth or cotton swab with isopropyl alcohol. Allow the device to dry completely before you connect it to power. Parent Topic: Device CareHomeDevice MaintenanceDevice CareCleaning the USB Port
