Ranging Display Overview
Pin indicator |
Indicates the rangefinder is locked on to the pin for the current hole and displays the distances from the pin to the front and the back of the green. (Measuring the Distance to the Pin) NOTE:
To use this feature, your rangefinder must be paired to the
Garmin Golf™ app or a compatible device (Pairing Your Phone,
Pairing a Compatible Device).
Battery indicator |
Indicates the battery level of the rangefinder. When the rangefinder is awake and the battery is low (under 10%), the battery indicator is always displayed. |
Bluetooth® indicator |
Indicates the
Bluetooth connectivity status.
Distance to target |
Displays the measured distance to a target (Measuring the Distance to a Target). |
PlaysLike distance |
The
PlaysLike distance feature accounts for elevation changes on the course by showing the adjusted distance to the green. When connected to a compatible device, the
PlaysLike distance feature also accounts for data provided by that device, such as wind and weather data.
NOTE:
Tournament mode disables the
PlaysLike distance feature (Using Tournament Mode).
