You can use the device to measure the distance from your current position to the pin.
NOTE:The device can measure distance to the flag up to 366 m (400 yd.).
Align the rangefinder reticle with the flag.
Select an option:
Press
to measure for 3 seconds.
Hold
to actively measure for up to 8 seconds.
If the device is able to lock on to the pin, your rangefinder vibrates and the measured range appears. If your rangefinder is paired to the
Garmin Golf™ app or a compatible device, the distances from the pin to the front and the back of the green appear (Pairing Your Phone,
Pairing a Compatible Device).
