Using Setup Mode In setup mode, you can change the unit of measure and the display brightness. From the ranging display, hold MODE to enter setup mode. The unit of measure setting flashes. Press MODE to scroll between the unit of measure options. Press to select the unit of measure. The display brightness setting flashes. Press MODE to scroll between the display brightness options. Press to select the display brightness. The rangefinder returns to ranging mode. Parent Topic: IntroductionHomeIntroductionUsing Setup Mode
