Troubleshooting Ranging Accuracy
External factors may affect ranging accuracy, such as ambient light, weather conditions, target reflectivity, and target size.
Larger objects are easier to target than smaller objects. For example, you should target the flag instead of the pin.
The device can target longer ranges in lower light conditions, such as on overcast days. Bright sunlight minimizes ranging ability.
Rain minimizes ranging ability.
The device can target longer ranges when measuring the distance to reflective or shiny objects.
The device can target longer ranges when the angle to the target is closer to 90 degrees. A smaller angle to the target limits ranging ability.
Parent Topic: Measuring the Distance to a Target
