Calibrating the Barometric Altimeter
You can manually calibrate the barometric altimeter if you know the correct elevation or the correct barometric pressure.
  1. Go to a location where the elevation or barometric pressure is known.
  2. Select Menu > Elevation Plot > Menu > Calibrate Altimeter.
  3. Follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-1AC988EB-48A2-46E6-89B0-35813E6324B2 v4
