Adjusting the Map Drawing Speed You can reduce the map drawing speed to conserve battery power. Select Setup > Map > Map Speed > Normal. Parent Topic: Maximizing the Battery Life
Adjusting the Map Drawing Speed You can reduce the map drawing speed to conserve battery power. Select Setup > Map > Map Speed > Normal. Parent Topic: Maximizing the Battery LifeHomeDevice InformationBattery InformationMaximizing the Battery LifeAdjusting the Map Drawing Speed
