My device displays the wrong units of measure Verify you selected the correct units of measure setting on the device (Changing the Units of Measure). Verify you selected the correct units of measure setting on your Garmin Connect™ account. If the units of measure on the device do not match your Garmin Connect account, your device settings may be overwritten when you sync your device. Parent Topic: Troubleshooting
My device displays the wrong units of measure Verify you selected the correct units of measure setting on the device (Changing the Units of Measure). Verify you selected the correct units of measure setting on your Garmin Connect™ account. If the units of measure on the device do not match your Garmin Connect account, your device settings may be overwritten when you sync your device. Parent Topic: TroubleshootingHomeTroubleshootingMy device displays the wrong units of measure
