Pairing Your Wireless Sensors
The first time you connect a wireless ANT‍+® or Bluetooth® sensor to your Garmin® device, you must pair the device and sensor. After they are paired, the device connects to the sensor automatically when you start an activity and the sensor is active and within range.
TIP: Some ANT‍+ sensors pair with your device automatically when you start an activity with the sensor turned on and near the device.
  1. Move at least 10 m (33 ft.) away from other wireless sensors.
  2. If you are pairing a heart rate monitor, put on the heart rate monitor.
    The heart rate monitor does not send or receive data until you put it on.
  3. Press Menu.
  4. Select Settings > Sensors & Accessories.
  5. Select an option:
    • To pair a club sensor, select Club Sensors > Add New.
    • To pair a different sensor, select Add New, and select the sensor type.
  6. Bring the device within 3 m (10 ft.) of the sensor, and wait while the device pairs with the sensor.
    After the device connects to the sensor, an icon appears at the top of the screen.
Copyright © Garmin. All rights reserved.GUID-7681996C-530F-4C69-80C4-3CD20D82746C v5
