Pro Settings
From the main menu, select .
- STALK MODE
Enables the option to enter a mode that prevents accidental key presses (Using Stalk Mode).
- AIM POINT POSITION
Displays the pixel position next to each aim point on the display.
- DECIMAL PRECISION
Displays the ranged value in decimal format.
- FLIGHT APEX
Displays an arc above the aim point that shows the highest estimated point the bolt reaches during its flight.
- AUTO BRIGHTNESS
Enables the device to set the display brightness automatically based on ambient lighting conditions. This feature is enabled by default.
- RANGE AND AIMPOINT ONLY MODE
Sets the device to display only the range and aim point after ranging the target.
- METER STICK
Enables a function that projects a scale measurement of one meter on the screen for the distance measured by the range finder. This setting is available only when the unit of measure is set as meters (Measuring the Size of a Target).
- YARD STICK
Enables a function that projects a scale measurement of one yard on the screen for the distance measured by the range finder. This setting is available only when the unit of measure is set as yards (Measuring the Size of a Target).
- DEVICE ALIGNMENT
Sets options to help you align the device on your crossbow.
- SECOND AXIS CALIBRATION
Sets options to move the aim point left or right (Calibrating the Second Axis).
