Device Alignment Settings
You can use the device alignment settings to make advanced adjustments to your device alignment. These settings can be useful to adjust for a tilted mounting rail.
From the main menu, select .
- SHIM
Displays a vertical line on the screen to help you shim the mount. You should always verify the vertical line aligns with a plumb reference point.
- TARE LEVEL
Resets the level to the zero value.
- SECOND AXIS CALIBRATION
Sets options to move the aim point left or right (Calibrating the Second Axis).
Parent Topic: Pro Settings
