Calibrating the Second Axis
You can use the second axis calibration setting to remove any angular offsets that may be present in your crossbow rail to scope interface.
  1. Select Settings > PRO SETTINGS > DEVICE ALIGNMENT.
  2. Verify the line on the display aligns with a plumb reference point, and press OK.
    TIP: If the line does not align with a plumb reference point, you should shim and level the mount before calibrating the second axis.
  3. Select SECOND AXIS CALIBRATION.
  4. Follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-693FA105-1B57-421A-AFE2-6D258F86A8B3 v2
