Measuring the Size of a Target
Before you can use the meter stick or yardstick feature, you must enable it (Pro Settings).
You can use the meter stick or yardstick feature to measure the size of a target from a distance.
The device displays the scale measurement of one meter or one yard at the measured distance. You can use the scale to estimate the size of your target.
Parent Topic: Using the Scope
