Other Service Kits
Description
Service Kit Number
Notes
Hinge Pins
S00-01000-20
Includes all hinge pins for the mount and steering system.
Hinge Pins and Bushings
S00-01000-46
Includes all hinge pins and bushings for the mount and steering system.
Steering System Bushings
S00-01000-30
Bushings for the upper and lower link hinge pins on the steering system.
Includes three sets of bushings. For the Force® Pro trolling motor, you should use the bushings marked 12-3 and 15-3.
Pull Handle and Hardware
S00-01000-26
Installing the Handle on the Pull Cable
Stabilizer Bumpers
S00-01000-62
See the Stabilizer Installation Instructions at garmin.com/manuals/force_pro_trolling_motor.
Propeller Hardware
S00-01000-28
Includes propeller nut, washers, propeller shaft pin and sacrificial anode.
Replacing the Propeller
Spanner Wrench
S00-01000-44
Required for removing and installing the transducer cable compression nut on the bottom of the shaft.
Removing the Transducer Cable from the Shaft
Propeller Drive Motor Power Connector Set Screws
S00-01100-31
Disconnecting the Cables
GUID-4961C943-E6C7-423B-AC7D-40EC5C713247 v2
July 2026
