Graphical Flight Plan Modifications
When performing a graphical flight plan update, only execute the flight plan modification on the LRU where the flight plan modification was performed.
Graphical Edit Mode is activated by using the Graphical Reroute Button on the Radial Menu or holding a waypoint or flight plan leg on the 'Map' and Weather' Application pages. Once Graphical Edit Mode is active, the Modification Button Bar is displayed and waypoints or locations on the map may be touched to reroute a new leg in the Active Flight Plan.
When rubber banding a leg or waypoint, the Search Radius surrounding the grab point is displayed inside a white circle. When editing the flight plan on the 'Map' Application page the Map Data Box is displayed above the circle. Displayed in the Map Data Box is the perpendicular distance from the original grab point and course angle offset from the original leg to the center of the search radius.
- Activating Graphical Flight Plan Edit Mode:
- Graphically Adding Waypoints Using the Graphical Reroute Button:
- Graphically Add Waypoints To The End Of The En Route Section Of The Active Flight Plan:
- Graphically Adding Waypoints Using the Rubber Band Method:
- Graphically Removing Waypoints Using the Graphical Reroute Button:
- Graphically Removing Waypoints Using the Rubber Band Method:
