Graphically Adding Waypoints Using the Graphical Reroute Button:
- Open the Radial Menu from which the flight plan is to be edited.
- Touch the Graphical Reroute Button on the Radial Menu.
Tap the desired locations for waypoints to be added between the initially
selected waypoint and the subsequent waypoint. If no location is within the
white Search Radius circle, a temporary user waypoint is created. If multiple
waypoints are in the white Search Radius circle a "Nearest Item" window will
appear.
- Scroll if necessary through the "Nearest Items" window to find the waypoint desired and touch it to add that waypoint to the flight plan.
- The new route will be highlighted in cyan.
- If necessary, touch the Undo Button to undo the most recent change made before continuing in Graphical Edit Mode.
- If adding multiple waypoints, repeat Step 3 until all desired changes are complete.
Touch the Done
Button to apply all changes to the active flight plan
and exit Graphical Edit Mode.
Or:
Touch the Cancel Button then touch the OK Button to remove all changes and exit Graphical Edit Mode.
Parent Topic: Graphical Flight Plan Modifications
