Graphically Add Waypoints To The End Of The En Route Section Of The Active Flight Plan:
- Open the Radial Menu over the last waypoint in the flight plan on the 'Map' Application page or 'Weather' Application page.
- Touch the Graphical Reroute Button on the Radial Menu.
Touch anywhere on the map to add a new
waypoint to the end of the flight plan. If no waypoints are located inside the white
Search Radius circle, a temporary user waypoint is created. If multiple waypoints are in
the white Search Radius circle a "Nearest Item" window will appear.
- Scroll if necessary through the "Nearest Items" window to find the waypoint desired and touch it to add that waypoint to the end of the flight plan.
- After selecting the desired point the new route to it is highlighted in cyan.
- Additional waypoints may be added at the end of the flight plan by selecting new point on the map.
- If necessary, touch the Undo Button to undo the most recent change made before continuing in Graphical Edit Mode.
- If adding multiple waypoints, repeat Step 3 until all desired changes are complete.
Touch the Done
Button to apply all changes to the active flight plan and exit
Or:
Touch the Cancel Button then touch the OK Button to remove all changes and exit Graphical Edit Mode.
Parent Topic: Graphical Flight Plan Modifications
