Graphically Adding Waypoints Using the Rubber Band Method:
  1. Activate Graphical Flight Plan Edit Mode.
  2. Touch and hold an existing waypoint or flight plan leg on the map until the white Search Radius appears.
  3. Continue to hold, and drag the point to a new location on the map. If no waypoints are located inside the white Search Radius circle, a temporary user waypoint is created. If multiple waypoints are in the white Search Radius circle a "Nearest Item" window will appear.
    1. Scroll if necessary through the "Nearest Items" window to find the waypoint desired and touch it to add that waypoint to the flight plan.
  4. After releasing the selected waypoint, the new route to it and from it will be highlighted in cyan.
  5. If necessary, touch the Undo Button to undo the most recent change made before continuing in Graphical Edit Mode.
  6. If adding multiple waypoints, repeat Steps 2 and 3 until all desired changes are complete.
  7. Touch the Done Button to apply all changes to the active flight plan and exit Graphical Edit Mode.
    Or:
    Touch the Cancel Button then touch the OK Button to remove all changes and exit Graphical Edit Mode.
190-03123-21 Rev B
October 2026
