Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature.
Three of these contacts can be used as emergency contacts.
  1. From the Garmin Connect app, select Menu symbol or Menu symbol.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Venu® Sq watch (Using the Garmin Connect App).
GUID-1C3C7630-B695-44C3-AF56-949C1D4889FB v5
December 2023
