Pairing Your Smartphone
To set up the Venu® Sq device, it must be paired directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your smartphone.
- From the app store on your smartphone, install and open the Garmin Connect app.
Select an option to enable pairing mode on your device:
If this is the first time you are setting up your device, press
to turn on the device.
If you previously skipped the pairing process or paired your device with a different smartphone, hold
, and select to manually enter pairing mode.
Select an option to add your device to your
Garmin Connect account:
If this is the first device you have paired with the Garmin Connect app, follow the on-screen instructions.
If you have already paired another device with the Garmin Connect app, from the
or
menu, select , and follow the on-screen instructions.
Parent Topic: Smart Features
