Changing the Bands
  1. Use a precision flat head screwdriver to push in the watch pin.
    Close-up view of the band being removed
  2. Remove the band from the watch.
  3. Select an option:
    • To install a new Approach® S70 band, align one side of the new band with the holes on the watch, push in the exposed watch pin, and press the band into place.
      Close-up view of the band being installed
      NOTE: Make sure the band is secure. The watch pin should align with the holes on the watch.
    • To install a compatible QuickFit® band, remove the watch pin from the Approach S70 band, replace the watch pin on the watch, and press the new band into place.
      Close-up view of quickfit band being installed
      NOTE: Make sure the band is secure. The latch should close over the watch pin.
  4. Repeat the steps to change the other band.
GUID-0F89E6A5-EC1C-4382-964E-27DC4B5FC932 v5
April 2026
