Wireless Sensors
Your watch can be paired and used with wireless sensors using ANT‍+® or Bluetooth® technology (). After the devices are paired, you can customize the optional data fields (Customizing the Data Screens). If your watch was packaged with a sensor, they are already paired.
For information about specific Garmin® sensor compatibility, purchasing, or to view the owner's manual, go to buy.garmin.com for that sensor.
Sensor Type
Description
Club Sensors
You can use Approach® golf club sensors to automatically track your golf shots, including location, distance, and club type.
eBike
You can use your watch with your eBike and view bike data, such as battery and range information, during your rides.
External Heart Rate
You can use an external sensor, such as the HRM 200, HRM‍-Fit™, or HRM-Pro™ series heart rate monitor, to view heart rate data during your activities.
Foot Pod
You can use a foot pod to record pace and distance instead of using GPS when you are training indoors or when your GPS signal is weak.
Headphones
You can use Bluetooth headphones to listen to music loaded onto your watch (Connecting Bluetooth Headphones).
Rangefinder
You can use a compatible laser rangefinder to view your distance to the flag while golfing.
Speed/Cadence
You can attach speed or cadence sensors to your bike and view the data during your ride. If necessary, you can manually enter your wheel circumference (Wheel Size and Circumference).
Tempe
You can attach the tempe™ temperature sensor to a secure strap or loop where it is exposed to ambient air, so it provides a consistent source of accurate temperature data.
GUID-0F89E6A5-EC1C-4382-964E-27DC4B5FC932 v5
April 2026
