Optional Floor Spikes
WARNING
Handle with care, especially when positioning the device before normal use or when relocating for service. Failure to use caution when positioning the device could cause the device to tip, resulting in crushed body parts or other severe injury.
CAUTION
To avoid potential injury or property damage, a two-person lift is required.
The preinstalled feet are designed for use on most surfaces. For improved decoupling from the floor, two sets of optional floor spikes are included. The short spikes are designed for use on hard floor surfaces. The long spikes are designed for use on carpeted surfaces and provide increased stability. Before installing the floor spikes, you must remove the preinstalled feet (Removing the Preinstalled Feet ).
GUID-01BDC3A7-6C48-4F80-BE5C-BD0E0D7E0CE7 v2
May 2026
