Installing the Long Spikes NOTE: You must remove the preinstalled feet before installing the long spikes (Removing the Preinstalled Feet ). Using the included hex key, thread one long spike 1 at least five revolutions into the threaded hole at each corner. Carefully lift the speaker upright. Using the included hex key, adjust each long spike gradually until the desired level and height of the speaker is reached. Using the included socket tool, install one panel nut 2 onto each long spike to lock its position. Lower the top acrylic panel down onto the base. Parent Topic: Optional Floor SpikesHomeOptional Floor SpikesInstalling the Long Spikes
