Installing the Short Spikes NOTE: You must remove the preinstalled feet before installing the short spikes (Removing the Preinstalled Feet ). Press one round floor protector 1 into the recess under each corner. Using the included hex key, thread one short spike 2 approximately five revolutions into the threaded hole at each corner. Carefully lift the speaker upright. Tighten the short spike until the floor protector drops directly below. Using the included hex key, adjust each short spike gradually until the desired level and height of the speaker is reached. Using the included socket tool, install one panel nut 3 onto each short spike to lock its position. Lower the top acrylic panel down onto the base. Parent Topic: Optional Floor SpikesHomeOptional Floor SpikesInstalling the Short Spikes
