Spy Pole Control Bar
The Spy™ pole control bar allows you to control Spy™ poles connected to the chartplotter.
You can select an item to engage or disengage it. The button illuminates when it is engaged.
Spy pole overlay bar
1
The name of the connected Spy™ pole associated with the control bar. If you have more than one Spy™ pole connected to the Garmin BlueNet™ or Garmin® Marine Network, select this to choose a different device to control.
2
Status of the Spy™ pole.
Propeller and sonar beam icon
Select to engage SpyLink™ synchronization. You can use this feature only when the Spy™ pole is connected to a compatible Garmin trolling motor (SpyLink Synchronization).
Crosshairs icon with letter A
Select to engage automatic SpyLock™ point locking ( SpyLock Feature).
Radar icon
Select to engage SpyScan™ search mode (SpyScan Search Mode).
Satellite icon
Select to engage OneVü™ sonar 360-degree scanning. You can use this feature only after you connect a compatible 360-degree sonar transducer, such as a Garmin GT360UHD, to the end of the Spy™ pole, and assign it to that Spy™ pole (OneVü Scanning Sonar).
Left arrow symbol and Right arrow symbol
Select to turn the Spy™ pole to the left or right in step increments.
Menu button
Select to open options and settings for the Spy™ pole (Spy Pole Options and Settings).
June 2026
