Spy Pole Options and Settings
You can configure the options and settings for a connected Spy™ pole, such as setting actions for the gesture remote or foot control and calibrating the heading sensor.
To open the Spy™ pole settings, you must first add the Spy™ Pole control bar to a screen. To view the settings, from the Spy™ Pole control bar, select Menu button .
NOTE: When the chartplotter first detects a new Spy™ pole connection, you are prompted to begin a setup wizard that allows you to set these configuration options and calibrate the heading sensor. You can use the settings in this menu at any time to update the Spy™ pole configuration or calibrate the heading sensor again.
SpyScan™
Starts and stops SpyScan™ search mode. Select Menu button to configure various SpyScan settings such as the angle, direction, and speed (SpyScan Search Mode).
SpyLink™
Starts and stops SpyLink™ synchronization with a connected Garmin® trolling motor (SpyLink Synchronization).
Auto SpyLock™
Starts and stops the automatic SpyLock™ point locking. Select Menu button to adjust the range of this feature ( SpyLock Feature).
Gesture Remote
Sets the actions associated with the buttons on a connected gesture remote.
Spy™ Foot Control
Sets the actions associated with the buttons on a connected Spy™ foot control.
Set Pole Name
Sets the name for this Spy™ pole. This is helpful when you have more than one Spy™ pole connected to the same Garmin BlueNet™ or Garmin Marine Network.
Installation > Transducer Auto Park
Sets the side to turn and park the Spy™ pole when it is stowed.
Installation > Setup Wizard
Re-runs the Spy™ pole setup wizard.
Installation > Calibrate
Sets individual calibration values independent of the setup wizard (Configuring a Spy Pole).
Installation > Connected Transducers
Sets the transducer or transducers installed on the Spy™ pole. If you have more than one transducer installed on the Spy™ pole, you can set the primary transducer used for functions such as the automatic SpyLock feature.
Installation > Auto Power On
Sets the power-on behavior for the Spy™ pole. By default, the Spy™ pole turns on automatically when it receives power. You can change this so that you must manually press Power button to turn it on.
Installation > Restore Defaults
Restores the Spy™ pole default settings, but does not remove calibration data or pairing data.
Installation > Factory Defaults
Restores the Spy™ pole factory-default settings, including calibration data. Also removes any pairing data with a chartplotter and other peripheral devices.
June 2026
