SpyLink Synchronization
SpyLink™ synchronization allows you to synchronize the movement of a Spy™ pole with a paired Force® trolling motor. When SpyLink synchronization is engaged, the sonar view from a transducer connected to the Spy™ pole turns in the same direction that you steer the trolling motor. When SpyLink synchronization is engaged, and the trolling motor is set to Anchor Lock, using the Force foot pedal turns the Spy™ pole instead of the trolling motor.
You can start and stop SpyLink synchronization from the Spy™ pole control bar (Adding the Spy Pole Controls to Screens), or you can program a button on the gesture remote or Spy™ foot control to start and stop synchronization.
June 2026
