Using the Flashlight
NOTE: Using the flashlight can reduce battery life. You can reduce the brightness or flash frequency to extend the life of the battery.
  1. Select Flashlight > ENTER.
  2. If necessary, use the brightness slider to adjust the brightness.
  3. If necessary, select a different flash type.
    0
    No strobe, constant beam.
    1 through 9
    Number of strobes per second.
    SOS
    Emergency strobe.
    NOTE: Wi‑Fi®, Bluetooth®, and ANT‍+® connections are disabled in SOS mode.
GUID-A921AB4F-381A-48D5-9BCC-9A895445C84F v11
October 2026
