Settings
Trolling Motor Settings
On the remote control, select Menu icon > Settings > Trolling Motor.
Wi-Fi
Sets the wireless network preferences for the trolling motor (Wireless Network Settings).
Calibrate
Calibrates the trolling motor compass (Calibrating the Trolling Motor Compass) and sets the trolling motor bow offset (Setting the Bow Offset).
Units
Sets the units of measure.
Battery Management
Defines settings related to the trolling motor battery (Battery Management Settings).
Beeper
Disables or enables the autopilot notification beeps.
Prop Stow Side
Sets which side of the trolling motor the propeller rotates to when stowing the trolling motor. This is helpful when you store other items near the stowed propeller.
Auto Power On
Turns on the trolling motor when you apply power to the system.
Heading Hold
Sets the behavior of the Heading Hold feature (Changing the Heading Hold Behavior).
Nav. Arrival
Sets the behavior of the trolling motor when you reach the end of a route. Anchor Mode turns on Anchor Mode at the end of the route. Manual turns the propeller off at the end of the route.
CAUTION
When using Manual for the Nav. Arrival setting, you must be ready to take control of the boat.
Anchor Gain
Sets the level of autopilot response when in Anchor Mode (Adjusting the Autopilot Response).
Navigation Gain
Sets the level of autopilot response when in other autopilot modes (Adjusting the Autopilot Response).
Clear User Data
Deletes all saved waypoints, routes, tracks, and your active track.
NOTE: If you are connected to a chartplotter, selecting this clears user data from both the trolling motor and the connected chartplotter.
Restore Defaults
Resets the trolling motor settings to the factory default values.
NOTE: Restoring default settings does not clear user data on the trolling motor or on a connected chartplotter.
Clear Diagnostics
Deletes system-generated data that is stored on the trolling motor for troubleshooting purposes.
On the remote control, select Menu icon > Settings > Trolling Motor > Wi-Fi.
NOTE: The active Wi‑Fi® mode is shown at the top of the screen.
Mode
Sets the Wi‑Fi mode. You can turn off Wi‑Fi technology, join the network of a chartplotter, or create a wireless access point to use the ActiveCaptain® app (Connecting to a Mobile Device with the ActiveCaptain App).
Setup > Name
Sets the name of the wireless access point on the trolling motor (ActiveCaptain mode only).
Setup > Password
Sets the password for the wireless access point on the trolling motor (ActiveCaptain mode only).
On the remote control, select Menu icon > Settings > Trolling Motor > Battery Management.
Indicator
Sets the appearance of the trolling motor battery indicator to either an icon or a numeric voltage value.
Battery Setup
Sets the type of battery connected to the trolling motor, which helps calculate the reported battery status.
Remote Control Settings
On the remote control, select Menu icon > Settings > Remote Control.
Backlight
Adjusts the backlight settings. (Backlight Settings)
Beeper
Sets the beeper to sound for key presses and alarms.
Auto Power Off
Sets the length of time before the remote control turns off automatically.
Calibrate
Calibrates the remote control for the gesture-control features (Calibrating the Remote Control).
Pairing
Pairs the remote control with the trolling motor (Pairing the Remote Control).
Language
Sets the on-screen text language.
Restore Defaults
Resets the remote control to factory default settings. This restores the default configuration settings on the remote control, but does not remove saved user data.
Backlight Settings
On the remote control, select Menu icon > Settings > Remote Control > Backlight.
Keys
Sets the backlight to turn on when a key is pressed.
Alarms
Sets the backlight to turn on when an alarm sounds on the remote control.
Timeout
Sets the length of time before the backlight turns off.
Brightness
Sets the brightness level of the backlight.
GUID-A7668193-255A-4F7A-AAEC-C153FB825CB4 v3
August 2026
