Stowing and Deploying Considerations
You can stow or deploy the Spy Pole™ mount in different ways to best suit how the device is mounted on your vessel.
NOTICE
You should stow the Spy Pole™ mount whenever your vessel is traveling at speeds greater than trolling speeds. Traveling faster than a trolling speed with the Spy Pole™ mount deployed may damage the Spy Pole™ mount or any devices mounted on it.
If the Spy Pole™ mount is mounted on a trolling motor, you should refer to the trolling motor stowing instructions (Stowing or Deploying the Spy Pole Mount on a Trolling Motor).
If the Spy Pole™ mount is mounted on the gunnel mount (not included), you should refer to the gunnel mount stowing instructions (Stowing and Deploying the Spy Pole Mount on a Gunnel Mount).
You can control how the Spy Pole™ mount reacts when you stow or deploy it by adjusting the automatic park settings from your chartplotter (Setting the Spy Pole Mount Automatic Park Settings).
GUID-5E9D5954-EED9-410E-9E9E-D57EBC1DBAD3 v2
September 2026
