Stowing and Deploying the Spy Pole Mount on a Gunnel Mount
If the Spy Pole™ mount is installed on a gunnel mount, you can stow or deploy it by manually rotating the gunnel mount.
  1. To stow the Spy Pole™ mount, unlatch the quick-release lever on the gunnel mount's horizontal tube.
  2. Rotate the Spy Pole™ mount until it is parallel to the water.
  3. Relatch the quick-release lever to hold the Spy Pole™ mount out of the water.
  4. Pull one of the silver security pins from the tube-connector bracket and push it through the concentric holes in the bracket and horizontal tube.
    The Spy Pole™ mount is securely stowed out of the water.
  5. To deploy the Spy Pole™ mount, remove the silver security pin and return it to the storage hole on the tube-connector bracket.
  6. Hold onto the Spy Pole™ mount while you unlatch the quick-release lever.
  7. Gently lower the Spy Pole™ mount into the water.
  8. Relatch the quick-release lever.
    The Spy Pole™ mount is deployed and ready to use.
GUID-5E9D5954-EED9-410E-9E9E-D57EBC1DBAD3 v2
September 2026
