Setting the Spy Pole Mount Automatic Park Settings
With the automatic park feature, you can set the Spy Pole™ mount to automatically rotate into a parked position when it is stowed. When deployed, the Spy Pole™ mount automatically rotates into the active position. This feature is disabled by default, but you can enable it through your connected chartplotter settings.
CAUTION
Take care when holding onto the Spy Pole™ shaft while stowing the device when the automatic park features are enabled. The device can rotate in your hands and can potentially cause minor injuries or damage the device.
NOTE: If you have the Spy Pole™ mount's automatic power-off feature enabled, the automatic park features will be disabled if the device powers off. The mount will then rotate freely. You can adjust the automatic power-off settings from a connected chartplotter.
  1. On a connected chartplotter, open the Spy Pole™ mount control bar.
  2. Select > Installation > Transducer Auto Park.
  3. Adjust the automatic park settings for your Spy Pole™ mount as needed.
GUID-5E9D5954-EED9-410E-9E9E-D57EBC1DBAD3 v2
September 2026
