Stowing or Deploying the Spy Pole Mount on a Trolling Motor
If the Spy Pole™ mount is mounted on a trolling motor, it is stowed and deployed automatically when you stow and deploy the trolling motor.
  1. To stow the Spy Pole™ mount, use the pull-cable on your trolling motor to pull the motor out of the water and into the stowed position.
    The Spy Pole™ mount moves out of the water with the trolling motor and rests in the stowed position.
  2. To deploy the Spy Pole™ mount, pull the pull-cable on the trolling motor back until it stops to release the latch, and hold it tight.
  3. Lift the motor and Spy Pole™ mount assembly up and forward using the pull-cable, then lower it slowly into the deployed position.
  4. If necessary, push down on the mount arm to lock the assembly in the deployed position.
    The Spy Pole™ mount and trolling motor are deployed in the water and ready to use.
GUID-5E9D5954-EED9-410E-9E9E-D57EBC1DBAD3 v2
September 2026
