Device Settings
The device settings allow you to customize the device for your needs.
From the main menu, select
- Pins
Sets the appearance and timeout of the pins on your bow sight (Pin Settings).
- Brightness
Allows you to adjust your pin and reticle brightness preferences (Adjusting Brightness).
- Pro Settings
Allows you to configure the pro settings. (Pro Settings).
- Level
Displays the angle of the bow and allows you to display a level indicator while shooting (Level Settings).
- Reticle
Allows you to turn on the rangefinder reticle and primary pin and to align them, as needed.
- Laser Locations
Sets the broadcast mode for laser locations (Laser Location Settings).
- Shot Dynamics
Enables or disables shot notifications and clears shot history (Shot Dynamics Settings).
- Bow Configuration
Allows you to enter the draw length, sight height, and sight length measurements for your bow configuration (Bow Configuration Settings).
- System Settings
Allows you to configure the system settings, calibrate the compass, and view regulatory and compliance information.
