Laser Location Settings
From the main menu, select .
- Broadcast Mode
Sets the security of laser location broadcasting. You can select Private to send locations only to a paired device.
- Forget Device
Removes the paired device so that you may pair with another device using private mode. You do not need to use this feature while using the public broadcast mode.
Parent Topic: Device Settings
