Adjusting Brightness
The bow sight contains an ambient light sensor to set your pin and reticle brightness automatically. You can adjust your pin and reticle brightness preferences if you prefer a different level of brightness. You can also adjust the pin brightness quickly by pressing
or
while using hunt mode.
- From the main menu, select .
Select an option:
To adjust the pin brightness, select Pins.
To adjust the rangefinder reticle brightness, select Reticle Brightness.
To adjust the screen backlight brightness, select Backlight.
To change the backlight timeout, select Backlight Timeout.
To enable or disable the ambient light sensor, select Light Sensor.
Parent Topic: Using the Bow Sight
