Using the Bow Sight
Before you can use the bow sight, you must calibrate it for your bow and arrow combination (Calibrating the Bow Sight).
  1. Hold the laser rangefinder trigger.
    TIP: You can range with the bow drawn or at rest.
  2. Align the primary pin with the ranging reticle, and aim at the target.
  3. While holding the reticle on the target, release the laser rangefinder trigger.
    The bow sight displays the measured range and projects a new pin.
  4. Using the new pin, aim at the target, and shoot the bow.
Copyright © Garmin. All rights reserved.GUID-4378DB68-8AE7-4523-866A-66DB070CBA65 v2
