Calibrating the Bow Sight
The first time you turn on the Xero® bow sight, you are prompted to go through initial setup steps. You can view tutorial videos at garmin.com/xerotutorials.
  1. Select a language.
  2. Select a unit of measure.
  3. Select Yes to start the pin calibration procedure.
  4. Follow the on-screen instructions to set the primary pin and calibrate the pin stack.
Copyright © Garmin. All rights reserved.GUID-4378DB68-8AE7-4523-866A-66DB070CBA65 v2
