Torque Specifications
When adjusting and tightening the adjustment knob lock screws, you should ensure the screws are always tightened to a maximum torque specification of 2.2 N-m (20 lbf-in.). If you do not have a torque wrench, you can tighten the screws until the screw head makes contact with the mount surface, and then tighten the screw an additional one quarter turn.
The mounting screws securing the riser mount to your bow should always be tightened to a maximum torque specification of 6.7 N-m (60 lbf-in.). If you do not have a torque wrench, you can tighten the screws until the screw head makes contact with the mount surface, and then tighten the screw an additional one half turn.
The set screw securing the bow sight to the riser mount should always be tightened to a maximum torque specification of 3.9 N-m (35 lbf-in.). If you do not have a torque wrench, you can tighten the set screw until it is snug, and then tighten the screw an additional 1/8 turn.
