Rangefinder Measurements
When you activate the laser rangefinder, the device displays three measurements on the LCD display, along with the arrow type and pin number. The device uses these measurements to adjust the position of the pin.
The horizontal distance to the target, which is calculated using the angle of measurement. |
The measured distance between the laser rangefinder and the target. |
The upward or downward angle from the rangefinder to the target. |
The type of arrow tip for the profile. |
The LED pin number of the ranged pin. |
Parent Topic: Using the Bow Sight
