Pro Settings
From the main menu, select .
- XD Mode
Enables a mode that allows you to extend the bow sight's range by setting an extended position on the elevation rail (XD Mode).
- Flight Apex
Displays a flashing LED above the aim point that shows the highest estimated position the arrow reaches during its flight.
- Pin Position
Displays the LED position next to each pin on the display.
- Decimal Precision
Shows more precise measurements for the laser rangefinder. Measurements are rounded to the nearest tenth of a meter or yard.
- Stalk Mode
Enables the option to enter a mode that prevents accidental button presses (Using Stalk Mode).
- Move Calibrated Range Stack
Allows you to move the calibrated pins to allow more adjustment in the direction of your choice (Moving the Calibrated Range Stack).
- Competition File
Enables the device to record shot dynamics to a file stored on the device. This can be useful to review shots taken during a tournament.
