Moving the Calibrated Range Stack
You can move the calibrated pins up or down to allow more adjustment in the direction of your choice. For example, if your primary pin is set at 20 yards, and your maximum pin is set at 70 yards, you can move the range stack up so you can add pins for farther ranges. Alternatively, you can move the calibrated range stack down so your pins are more centered within the device optic. You must adjust your mechanical alignment after moving the calibrated range stack. Moving the calibrated range stack updates all arrow profile settings.
NOTE:
The device stores pins that are positioned above or below the optic. These pins are still listed as calibrated ranges, and can be moved back onto the optic at any time.
- From the main menu, select .
- Select Yes.
Press
or
to adjust the position of the range stack.
- Press OK.
- Follow the on-screen instructions to calibrate the device for the new stack position.
Parent Topic: Pro Settings
