Power-Pole Overlay
Before you can control the Power-Pole® anchor with the chartplotter, you must enable the overlay (Enabling the Power-Pole Anchor Overlay) and set the Power-Pole installation mode (Setting Up the Power-Pole Anchor).
The layout of the overlay varies based on the installation mode. Refer to your Power-Pole documentation for more information.
Select to control both anchors simultaneously Deselect to control the anchors independently |
Select to fully retract the anchor |
Select to fully extend the anchor |
Hold to retract the anchor manually Release to stop the anchor |
Hold to extend the anchor manually Release to stop the anchor |
Select to open the menu |
PORT |
Port side anchor control buttons |
STBD |
Starboard side anchor control buttons |
