General Settings
NOTE: When the stereo is in a group, you cannot change the settings on that stereo.
Select Menu button > SETTINGS, and select the name of the stereo.
NOTE: When a check box is filled, the option is on. When the check box is clear, the option is off.
DEVICE NAME
Sets a name for this device.
TUNER REGION
Sets the region used by the FM and AM sources.
This setting is also needed to configure DAB and SiriusXM® sources.
TELEMUTE
Sets the behavior of the stereo when it detects a signal on the TELEMUTE wire in the wiring harness. This is commonly used to change to the Aux source when you hold the button on a Fusion® handheld microphone. You can also choose to either mute the audio or change to the Aux source when connected to a hands-free mobile phone kit. See yourFusion handheld microphone or hands-free mobile phone kit instructions for more information.
NOTE: This setting does not affect a phone connected to the stereo using Bluetooth® technology.
POWER OPTIONS
Adjusts the power settings, such as the GROUP SYNC.
SEARCHING
Enables Fusion Alpha Search Technology (FAST), which allows you to quickly search for tracks by letter or number. You can select a number to enable the FAST menu if your music device contains more than the selected number of items.
ZONE
Enables you to configure the speaker zones (Speaker Zone Settings).
SOURCE
Allows you to enable, disable, and name the sources and groups on the stereo (Source Settings).
NETWORK
Enables you to configure the Fusion PartyBus™ network settings (Network Settings).
UPDATE
Updates the stereo or connected devices using the appropriate update file on a connected USB flash drive (Update Options ).
NOTE: It is not necessary to use this menu if you are updating the software using the Fusion Audio app on a mobile device instead of using an update file loaded onto a USB flash drive (Updating the Software Using the Fusion Audio App).
UPDATE > FACTORY RESET
Restores all settings to the factory default values.
ABOUT
Shows the software version information for the stereo and connected accessories.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
