Update Options
NOTICE
Do not turn off the device or disconnect the power during a software update. Turning off the power during a software update may cause the device to become unresponsive.
Depending on your stereo and network connections, you may have multiple software-update options available. Before proceeding with an update, you should examine your devices and connections to determine the most efficient way to proceed (Software Updates).
NOTE:
  • The device may restart a few times when updating. This is normal.
  • You can program only newer versions of software on the device.
Select Menu button > SETTINGS > UPDATE.
UPDATE DEVICES
Updates the stereo using a valid software update file on a connected USB flash drive (Updating the Software Using a USB Flash Drive).
ACCESSORIES > NRX REMOTE
Updates an optional NRX remote connected to the NMEA 2000 port or NMEA 2000® network.
ACCESSORIES > ERX REMOTE
Updates an optional Fusion Apollo™ ERX400 remote connected to the ETHERNET port or the Fusion PartyBus™ network using a valid software update file on a connected USB flash drive (Updating the Software Using a USB Flash Drive).
ACCESSORIES > DAB MODULE
Updates an optional DAB module connected to the SIRIUS XM port.
SAVE GARMIN DEVICES
Saves connected device information to a connected USB flash drive. This information is required by the Garmin Express™ program when preparing the USB flash drive with the proper software update files.
FACTORY RESET
Resets default settings.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
