Network Settings
NOTE: If a Garmin® chartplotter is detected on the network, the stereo automatically switches to GARMIN MARINE NETWORK mode, and all other network settings are disabled.
Select Menu button > SETTINGS, select the name of the stereo, then select NETWORK.
DHCP CLIENT
Sets the device as a DHCP client. This is the default setting for all devices that are not configured to be a DHCP server.
STATIC IP
Allows you to set a static IP address for the device (Setting a Static IP Address).
DETAILS
Shows information about the network configuration.
ADVANCED
Allows you to configure the DHCP server and reset all network settings for this stereo to the factory default values.
SAVE
Allows you to save changes to the network settings.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
