Setting the Stereo as a Wired DHCP Server
If you connected more than two network devices together directly or using a network switch or wireless access point and did not install a router, you should configure only one Fusion PartyBus™ stereo to be a DHCP server.
NOTE: Although the Fusion PartyBus devices can communicate with each other without a DHCP server on the network, the devices take longer to connect to each other when you first turn them on. It is highly recommended to have a properly-configured DHCP server on the network for the best results.
NOTE: If your vessel has a mix of Garmin® Marine Network and Garmin BlueNet™ networks connected through a Garmin BlueNet bridge, all stereos must be connected to the Garmin BlueNet network.
  1. Select Menu button > SETTINGS.
  2. Select the name of the stereo.
  3. Select NETWORK > STATIC IP > SAVE.
    You must set the stereo to use a static IP address before you can set it as a wired DHCP server.
  4. Select ADVANCED > DHCP SERVER > DHCP ENABLED > SAVE.
    You can configure the IP address range of the DHCP server (DHCP Settings).
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
