Updating the Software Using the Fusion Audio App
If the stereo is connected to a Fusion PartyBus™ network with a Wi‑Fi® access point, you can update the stereo software using the Fusion® Audio app, available for compatible Apple® or Android™ on the Apple App Store℠ or the Google Play™ store.
If you have a compatible Apple device, you can use a Lightning™ to USB sync cable (sold separately) connected to the USB port on the stereo and to your Apple device to update the stereo software through the Fusion Audio app.
Do not turn off the stereo or disconnect the power during a software update. Turning off the power during a software update may cause the device to become unresponsive.
NOTE:
If the stereo you want to update is in a group, you must remove it from the group (Leaving a Group).
NOTE:
- The stereo may restart a few times while updating the software. This is expected behavior.
- You can program only newer versions of software on the stereo.
Parent Topic: Software Updates
